ATI Radeon HD 5870 Architecture Analysis
Written by Tim Smalley
September 30, 2009 | 17:58
Tags: #5870 #analysis #architecture #compute #cypress #directx11 #dx11 #evaluation #feature #g80 #geforce #gt200 #hd #opencl #performance #radeon #review #rv870
Companies: #amd #ati #nvidia
Vertex/Geometry Shader Performance
There's more to the DirectX pipeline than just pure pixel shader performance though – here, we use a combination of geometry and vertex shader-bound tests to determine Cypress's performance in these areas.
Tests
Test Kit
  • Intel Core i7 965 processor (3.2GHz: 133MHz x 24)
  • Asus P6T V2 motherboard (Intel X58 Express)
  • 6GB Corsair TR3X6G1333C9 DDR3 memory (3x 2GB, 1,333MHz, CL9)
  • Corsair X128 SSD
  • Corsair HX1000W PSU
  • Windows Vista Home Premium x86-64 (with Service Pack 2)
  • Antec Twelve Hundred Chassis
  • HD 5870: Catalyst 8.66 RC6 Windows Vista/7 (September 11th Build)
  • All other ATI: Catalyst 9.9 WHQL
  • ] Nvidia: ForceWare 190.38 WHQL
D3D10 - RightMark 3D 2.0: GS Galaxy
1,920 x 1,200 0xAA 0xAF, High Polygon Count, Heavy GS Load
  • ATI Radeon HD 5870 1GB
  • ATI Radeon HD 4890 1GB
  • Nvidia GeForce GTX 285 1GB
  • Nvidia GeForce 8800 GTX 768MB
  • ATI Radeon HD 3870 512MB
    • 68.6
    • 67.3
    • 63.2
    • 35.5
    • 28.2
20
30
40
50
60
70
Frames Per Second
  • Frame Rate
D3D10 - RightMark 3D 2.0: GS Hyperlight
    • 216.6
    • 165.6
    • 154.9
    • 70.1
    • 51.3
100
150
200
Frames Per Second
  • Frame Rate
D3D10 - 3DMark Vantage: GPU Cloth
GPU Cloth Test, Default Settings
    • 30.7
    • 30.4
    • 22.2
    • 22.2
    • 12.2
10
15
20
25
30
Frames Per Second
  • Frame Rate
Our geometry shader-targeted tests don't reveal anything out of the ordinary on the Radeon HD 5870 - GS Galaxy is typically CPU limited, while Hyperlight is a more accurate reflection of pure geometry shader throughput. 3DMark Vantage's own geometry shader test is something of a curve-ball though, as it clearly favours Nvidia hardware (we've disabled PhysX in the driver just in case the driver tries to do something funky, for what it's worth). The Radeon HD 5870 is on a par with the GTX 285, so we can expect GT300 to push the boat out in this particular test.
D3D10 - RightMark 3D 2.0: VTF Earth
1,920 x 1,200 0xAA 0xAF, High Effects Detail, High Polygon Count
    • 494.4
    • 407.7
    • 374.0
    • 309.9
    • 231.1
200
300
400
500
Frames Per Second
  • Frame Rate
D3D10 - RightMark 3D 2.0: VTF Waves
    • 288.8
    • 240.9
    • 171.2
    • 150.9
    • 121.9
100
150
200
250
300
Frames Per Second
  • Frame Rate
Dropping back into RightMark3D for the vertex texture fetch tests swings things back the other way - the Radeons dominate proceedings here. The complexity of the scenes favours the AMD hardware, which is able to better cope with the loads being placed on the GPU. We also ran the same tests at lower detail and found that the GeForces fared much better.
null
